Hi guys, the title says it all! I flashed a few roms recently, but didnt really feel that excited about them, so kept reinstalling my nandroid backup. So far so good. Anyway, I came across another rom that looked worth a try, "Imperium". So went through the usual process of downloading it to my phone, etc, etc, and started the installation. And thats where my problems began! The customisation choices that you have to make are huge! Theres a page of selection choices for just about every aspect of the installation, and I guess I made a few wrong choices. When everything was done, and the phone rebooted.......it didnt! It just got to the Samsung logo, and sat there flashing at me. So, after a while, I rebooted it and exectly the same thing happened.
I rebooted into recovery, and tried to install the nandroid backup, but it told me there were no files found!
I can get into recovery and download mode ok, but thats it.
Ive tried flashing a stock rom using different Odin versions, but it gets stuck at either "setup connection" or " Writing Nand" at least something like that.
Ive tried installing a zip file from sideload, but it just wont play ball, I think, mainly because I dont understand the instructions well enough.
So thats where I am basically. I am also not at home, but house sitting at my daughters,(hence deciding to play with my phone) but have a laptop,(hers) and a usb cable with me.
My last hope seems to be to try and install a zip rom from an external sd card, which I have at home.
Ive obviously wiped all the files off the internal sd card ( I guess) by ticking a wrong choice during the Iperium rom setup choice procedure.
Can anyone give me hope? Like "Ah, just do this and this, and all will be well"? I'm all out of ideas, apart from the external sd card method.
Thanks for any suggestions.
Dave
Dave
