Shotgun84
Extreme Android User
KT-SGS4 Jellybean kernel features
•Must have a Touchwiz Rooted ROM
•Linux kernel 3.4.54
•Samsung open source
•Optimized kernel configuration
•unsecure root adb
•Voltage interface
•CPU Overclocking
•CPU Underclocking
•Boots on stock table (USE KTweaker app to enable OC steps all the way to 2322 Mhz. BE AWARE THAT I WAS VERY CONSERVATIVE ON THE LOW SIDE OF THE OC STEPS, SO THEY WILL NEED SOME TWEAKING!)
•KTweaker app for kernel control
•KTweaker Widget
•Schedulers (CFQ, BFQ, VR, SIO, NOOP, DEADLINE, ROW, FIFO, FIOPS)
•GOVERNORS (ktoonservativeq, intellidemand, msm-dcvs, wheatley, userspace, smartassh3, slp, powersave, pegasuq, nightmare, interactive, dancedance, conservative, badass, asswax, adaptive, abyssplug, performance, ondemand
•Thanks to Talustus we now have exFAT for Touchwiz and AOSP
I'd noticed that when playing that helicopter sample video with Adam and Cf-auto root the playback would appear choppy (no pun intended, ok it was) and would pause every 5 to 10 seconds so I went hunting. I didn't really look too far as this was the next one I tried and I have to say I'm impressed. Due to a problem with 3minit where I'd had it set up to turn the torch on by long pressing home when on the lockscreen my flashlight was on whenever I took my phone out of my pocket. I would've expected my battery to take a much bigger hit than it did because of this but it held out nicely. Everything seems nice and smooth and video playback and online streaming works flawlessly. There's also more options to tweak than you can shake a stick at, all customizable using the KTweaker app which gets installed when you flash. Maybe a little too many for me until I've done a bit of reading so I've basically got it set up with the devs settings that he posted in his thread.
Original thread and download
http://forum.xda-developers.com/showthread.php?t=2297379
•unsecure root adb
•Voltage interface
•CPU Overclocking
•CPU Underclocking
•KTweaker Widget
