Root [International] Needing Help to fix a failed root
I would pull the battery as Funky says.
Reboot into recovery and see if you have got as far as having a custom recovery. If you have you may be able to just wipe Cach / Dalvik Cache and it may reboot.
If not, and you have a custom recovery, try re-flashing the custom ROM.
Failing that.......
Go to sammobile and find the original Samsung Rom for your phone and load that via odin.
Reboot it normally, to make sure it works...then flash it again.
