Scorpio001
What are the steps need to get stock Android 4.1.2 on the Note 2 International model?
Do you only root it once?
Do you need to find the correct ROM for the right model? How to tell which model for the right ROM?
Do you still get OTA direct from Google or wait for the modified ROM version?
Thanks.
Thanks.
