Root [International] [Rooted] WI-FI issue
I have a slight problem with Wi-fi not able to switch off while turned on cos the toggle is greyed out unless i reboot.
This happens when Wi-fi goes to sleep and 'wakes' up again after a duration when i power on the screen. I'm unable switch it off unless i disconnect my network in settings>wifi. This also prevents my Wifi not switching off when going back to sleep too. :/
I have the HTC One M7, ViperRom8, Rooted, S-OFF, 7.19.401.2 firmware.
Any advice or solution will be appreciated, Cheers!
Are you using TWRP recovery as that is the required one for that rom, if so then:
Have you checked through to see if this is a bug with the rom.
If so & it is not it may be worthwhile downloading the rom again & reinstalling it.
