DroidFaller
Anyone know how to turn off WiFi when mobile data is on or turn mobile data off when WiFi is on on tasker?
Thanks
Thanks
Thanks
Android does this automatically, no need for profiles to make this happen.
sounds like the backups are still on your phone memory but dont worry, when you do a reset in a custom recovery (philz/clockwork), it doesnt wipe the internal SD. Just dont use the factory reset in the phones settings.
Next time you make a nandroid, just choose "back up to sd card" :thumbup:
Even though i flashed Philz recovery are all my files going to stay the same? Or is it going to make a philz recovery folder?
