saltire
Android Expert
Can't for the life of me figure out where I'm going wrong trying to install the Domination theme - each time reboot get a message saying unfortunately SystemUI has stopped working and have no notification bar. Was trying this over WanamLite with no other themes or mods applied, and Siyah kernel.
Now running Omega with Motomoto theme which installed fine, so don't get where I was going wrong with Domination install.
Although quite like Omega/Motomoto theme so am going to stick with it for a while - but don't like (and can't read the percentage!) the battery icons. So question is if I add current SystemUI.apk to a flashable CWM script zip file, can I then open zip in 7-zip, navigate to the correct drawable folder in the apk (still in 7-zip) and drag new set of battery icons across to replace themed ones?
If this'll work, can someone point to some battery icon sets I could try out
ta.
ta.
