Gentle Jesus
Hello guys
I just got my HTC one X today, Rooted it with this guide Ultimate HTC One X Guide To Tweaking, Flashing and Modding | Captain Debugger
Then I started installing some apps for it. I installed ADW Launcher EX and found that the 3 dot menu bar is at the bottom so I searched on line on how to remove it and came across this website Disable 3-dot Menu On HTC One X & Map Menu to Task Switcher Button
So I downloaded the zip that lets you remove the 3 dot bar and instead to access the menu I just long press the home key.
So next I put the zip file on the the memory of the phone and booted the zip rom through clockwork recovery. It was installed successfully.
I reboot the phone and now and it is stuck on the "HTC One x Beats audio" boot screen.
Any idea on whats happened and how I can fix this.
Would be great as I only got it a few hours ago ^^
Regards
Gentle
Regards
Gentle
thanks
