Root [International Tegra 3] CM10 Bootloop
PGA_UK
Having owned HTC Desire and flashed CM7, decided to flash One X. Rooted and CWM went ok, copied across CM10 Zip file and installed.
Phone booted, all looked like it was going ok, but then CM10 logo appeared and phone will not get passed logo. In Fastboot USB, storage cannot be seen form PC. IN CWM Recovery, can mount SD Card, Can format card,etc but cannot mount USB (missing lun file).
Now, as I cannot gain access to the sdcard, I cannto push any new roms on to card, so cannot re-flash...
Any ideas?
PGA, I faced a similar problem while trying to install CM10 to my friend's HTC One X. It did not want to get past the booting screen and CWM did not want to mount as USB storage.
What I did was I downloaded and installed the latest version of Clockwork Recovery Mod (5.8.4.0 I believe) and all went well afterwards.
Please grab it from here:
ClockworkMod ROM Manager - Recoveries
Get the "Touch" version since it's easier to work with.
This is how you install the recovery:
Place the recovery img into your fastboot folder
Open a command prompt window from there (hold shift on your keyboard, right click on any empty area in the folder, and click Open command window here)
Type "fastboot devices" without the quotes to make sure your device is detected
Then type "flash boot recovery insert_recovery_name_here.img" of course with no quotes and you'll put the recovery img's name in place of the one I wrote above and add .img at the end of the line (no spaces)
Then hit enter and it should succeed afterwards.
