Root [International Tegra 3] OTA update error with CWM installed
Rushey
Hi
The system is telling me I've got a system update so I've downloaded it and clicked on Install Now. After reboot I get the CWM 5.8.2.7 menu with an "installation aborted" message.
What can I do to install the update?!
Thanks
Rob
Clockwork won't install OTA Updates so if you want to apply, you'll need to flash stock recovery, then try to install.
Alternatively, you could flash a custom ROM?
Do it! :p
ARHD is good, but I'm using Energy at the moment (there's a link in the Guide sticky by DURX). Easily as slick and as good on battery as ARHD and it's themed Blue.
I need to install the update. I have ClockworkMod but can't install it. The thing is I am a noob with rooting, flashing and all that. So, If you could just tell me how to go about it, it'd be great.
I need this update real bad as it fixes the over-heating problem. PLEASE Save MY Soul.
