Root [International Tegra 3] Quick Tip Please
I've got an HTC ONE X (the Tegra 3 one) with Endeavoru and Android 4.2.2 and I've unlocked my bootloader through the HTC website, but now I don't know what is the best way to get it Rooted. If anyone can point me in the right direction or the right way/tips/points or even the right post for my type of phone I'd be really grateful . ^_^ thx
(P.S. I don't want to put a custom mod, maybe later on but for now I just want to have it rooted :D )
You'll need to flash a custom recovery for root, if you've unlocked the bootloader, it's relatively simple.
Download the latest TWRP from here: Techerrata Downloads - Browsing endeavoru
Place that in your fastboot folder, boot to fastboot, connect your phone to the PC, open a command prompt, navigate to the folder where the recovery image is and type
Code:
fastboot flash recovery XXX.img
XXX is the name of the file you downloaded.
You can then root using one of the toolkits: [TOOL] HTC One X (Tegra3) All-In-One Toolkit | HTC One X > XDA
Edit - In fact, looking at the tool, it will flash your recovery for you too. Just choose your own recovery and use the image file you downloaded from the TWRP website.
Does that all make sense?
Any bricking chance involved?...and can I use any one of those img. files?
Edit: And would it be recommended to use the last version of the IMG or is there any better one?
Thx
Unless it's just released, I'd always use the latest version.
Also, minimal chance of bricking if you use the toolkit, it will eliminate most of the human error side of things (typos etc).
Do you know if your handset was network branded before hand? If no, there's something called an RUU which can take you back to stock if something bad happens.
El Presidente...you the man..man xD...Thank you alot
It worked with the fastboot command...didn't even need the toolkit apparently as the recovery installed the super user by itself.
Thank you and many debugging successes in the future with everyone else >:D<
Awesome, glad you're rooted! :)
I forgot TWRP installed the SU binaries!
If you're looking for help installing a ROM at some point, I'll be happy to help with that too. :)
