Root [International Tegra 3] [Solved] Bricked? Facing some problems.
This is the situation:
I tried to install Cyanogenmod 9 to my new One X, but I forgot to move the gapp (or something like that) to my phone, and when I tried to restart my phone with supposedly Cyanogenmod 9 installed, I get stuck at the skating android.
I have tried cleaning all kinds of caches, and I am doing my best not to panic.
So how could I get my phone working again, I don't care if I lose root or anything.
Edit: I have the situation under control... you can't imagine my relief...
Welcome to AF! :)
Sounds like you had what's called a bootloop; don't worry, if you're flashing ROMs often, I'm sure it will happen again (it's nothing to worry about).
hello i had my htc one x now for about 2 months i rooted and it worked perfect next day ii went on it does not even turn on tried everything holding power and volume still not working i really need help i think it is briked thnx need help :(:(
Hi zak, welcome to AF. :)
Is it possible it's just run out of charge? Have you tried charging it? Do you also know what recovery and version you had installed?
