If this is your first ROM flash, and you won't have a custom kernel, so just click no there.
Try flashing a custom kernel then the ROM
What kernel do you suggest? Also, what ROM do you use? I kind of want a sense rom because well, I don't want to discard sense without even using it.![]()
P.S: What in your opinion, is the best ROM out there?
don't own the device
(yet!) Do you have the one x or the one XL?
I have the One X and its been a pretty fun first day. I've never owned an android device before and I gotta say, I'm pretty darn impressed. Glad I dived right into rooting/flashing, learnt quite a bit lol. Though my folks won't be so pleased when they find out that I voided my warranty on the first day
AhI have the One X and its been a pretty fun first day. I've never owned an android device before and I gotta say, I'm pretty darn impressed. Glad I dived right into rooting/flashing, learnt quite a bit lol. Though my folks won't be so pleased when they find out that I voided my warranty on the first day
that phone looks nice if I get some cash I might pick one up to do some development with
maybe bring my ROM over
On your PC, you need to open the rom zip file, extract the file called boot.img and place it in the folder which contains your fastboot exe.
Boot into hboot, connect your phone to the PC, in hboot, select fastboot. Once there, it should say Fastboot usb about a third of the way down the screen. Once it says that, open a command prompt on your PC, navigate to the fastboot folder and type:
fastboot flash boot boot.img
Then press enter. Let it do its thing then type:
fastboot erase cache (press enter again).
Once done, reboot and you'll load into the ROM (hopefully). Bear in mind, the first boot can take 10 or so mins.
Thanks, gonna try this out now!
Haha yeah just be careful my door is always open if you need helpthat phone looks nice if I get some cash I might pick one up to do some development with
Oh and pm me when that ROM is done, I'd love to check it out!
hope it all works out ill be around
Nope, don't work. Phone reboots, goes past the start screen, I see my wallpaper for about 10 seconds, then reboots and the same thing happens over and over.
