sherlock5545
Android Expert
Well, as the title says, I recently purchased ROM Toolbox, and I already had Titanium Backup PRO. I noticed the former does also the same job of the latter, which is backing up apps + data, and has many batch operations just like Titanium.
Now, I also noticed that both of these two apps generate backup files in .gz format. I was wondering, are Titanium's backup files compatible with ROM Toolbox, and vice versa?
Also, which one should I use? Since both of them do the same job, and ROM Toolbox does even many other tasks, is it worth keeping Titanium along with it?
Thanks!
Thanks!
