Yeah you'll need to reflash your stock firmware as that will replace your rooted kernel with the stock unrooted. I'm not too sure how easy it'll be too flash though as you have the new locked bootloader and knox. I'm not too sure either if reflashing will trip the knox counter. I've moved this to all things root![]()
What will happen as soon the official android 4.3 update comes for the galaxy s4. Better to wait for it?
will then the root access be gone?
what you mean by "upsets?"
Well i never ever installed any custom rom. Only thing i did was rooting it and thats all.
If your Knox counter is anything but 0x0 don't bother with resorting the phones flash counter and 'custom status", there really is no point. However if your firmware does not have Knox activated (as I said I'm not sure) you need 'Triangle Away' from here :
