Internet Connection
Hi All,:)
I'd like to connect to the internet on the android by using USB cable which is connected to my PC. means I want to use computer connnection to access the internet
Could I do it?
Thanks,,,:D
It's called USB tethering. Checkout the Easytether app from The Market. I think you will like it.
Actually it's called Internet Psss-Through. Tethering is using your phone's internet for the computer. He wants to do the opposite.
As stated above, only some HTC phones have this ability. If your computer is connected via ethernet, and you have a wifi card, you can use Connectify to make your computer into a wifi hotspot for your phone.
sitlet you're right that is what I mean (the opposite) I've galaxy Sll I hope to find way to do so,
Thanks all for your replay:):):),,,
