internet connection
  • Start date Start date
A
Android Question
Guest
My apps can't seem to connect to the internet even though it says I am connected.
Hi
You don't say if you mean Internet over data or wifi. If Wifi, it's quite possible for you to be fully connected to the wifi router but for the router not to have an Internet connection. See if other devices can connect on the same wifi network. If not its probably an issue with the routers connection to the ISP.
Roger
