Internet Help Anyone PLEASE!!!!!!
I had rooted my phone and all was well then bout a week later i was not able to use the internet. I can if i am using wifi but not always am i at home or a place with it. every time i leave i get a message that states cannot connect to internet check your connection settings and try again. well I have checked my connection settings and all is good. I also get the twlauncher message once in a while. Please anyone that can help please do so. I did get recommended to flash a custom rom but I have no clue on how to do that and I also dont want to damage my phone worse than it already is. thanks for any help I can get.
Next time you get a phone make sure you can unroot or reflash stock image in case you mess up or bad a rom , this situation your in now. a rom is easy to install on your phone in the sd card place a custom rom in the root of your sd card. you need to use rommanager and flash clockworkmod recovery to your phone boot into recovery how ever you do that i do not know your device now.
make sure to do a factory wipe data,clear cache, clear dalvik cache then choose zip and install rom reboot and enjoy.
Yea sorry Calvin anyways I just cleared it and same stuff no Internet. It happened rite after I installed superuser. Do you think it might have to do with that?
