Help Internet issue
I have purchased a Lenovo K4 note last week. From then on the 2G internet is on which means I can access all the apps but unable to open a web page. When I try to open a webpage I get a message as "This site cant be reached", "Err_connection_timed out" so please check and suggest what can be done. Its the same issue in all the browsers.
Hi Parayilhussain,
That fixed the issue but sometime still gives same error and when I try to open 10 times only 8 times it works. But in Chrome browser there is no change it never connects so I will try resetting chrome. Also now the webpages are very slow in loading so can you please provide some inputs on the same?
Settings >storage>cached data>clear cache.
Settings>storage>apps> download
Manger clear data.
Uninstall updates in chrome and
Reinstall updates from google play store.
Settings>data usage>>>uncheck for
Apps in " restrict app background data "
Disable power saving mode (if enabled).
Try to use Internet in outdoor.
However, I now have a new issue. When I use a Vodafone 2g internet on this phone it is too slow but on my old phone, it was normal. I'm confused.
