Default browser was connecting till a few days back. But suddenly it stopped connecting to even google.
But opera mini is connecting normally and all other GPRS related applications like gmail, youtube are connecting.
You probably set Opera Mini as the default app. Go into Settings > Applications > Find Opera and in the Opera information there is a section called "Launch by Default" click the button that says "Clear Defaults". Check that and any other browser you have.
no, i think its error android from samsung. cause i was bough samsung galaxy 5 and default browser cant to use. recently i buy samsung ace and default browser cant work optimal. Sometime its work, but very slow
I also faced the same problem. Installing opera mini had fixed the problem.
Thanks Guys.
But is there not any work around to use default browser? "Clear defaults" option is not highlighted. I am not able to put a check on it.
