internet not working
my inbuilt phone browser is working fine..but any app related to internet is not working..wifi is working,
model galaxy s i9003
version 2.3.5
plsss help
Hello and welcome aboard. Uninstall/reinstall one of the apps that wont connect to the internet.. and see if that makes a difference. It might just be the installed applications.
Also before you start one of the applications that is not working with your internet, click the wifi off, and then back on again. Wait a few seconds and try launching the app again, if you are using 3 or 4g just make sure your in a spot with a high signal. Sometimes the apps take a larger chunk of data to get going and you might not notice the significant slowdown with regular browser use. Goodluck
