Just got my motorola xoom (wifi and 3g) few days ago, internet connection is always unstable, every now and then it stops loading and browsing for no reason, that happens during both wifi and 3g connections.
I am actually confused wether it is a hardware or software problem.
If this was happened with wifi only I could say it is a problem with the wifi antenna, and if it was with 3g only I could say it is the 3g antenna or the service provider, but both, I do not this it is a hardware problem.
I thisk most probably it is android's problem, but I do not know what to do, I will try factory reset, although I did not load many application, the tab is already with its factory settings, and does not need any reset.
The problem with the internet connection not the internet browser only, because it happens during youtube, market application, maps application, downloading.
Any ideas where does this problem come from?
Thanks
Thanks
