Introduction - Jonesli
jonesli
Hi all - I hear you are a friendly bunch (says so on the website) so I pleased to meet you. I own a Samsung Galaxy Tab 7'7 (P6800) and am having a serious problem I hope you can help me with. I'm not very techie so I doubt I'll be able to repay in kind.
I recently tried to update the tab to Jelly Bean 4.1.1 using CyanogenMod (via ClockworkMod Recovery). I believe I followed the instructions to the letter and everything seemed to go smoothly. However, I cannot reboot or start up. I get the Cyanogen logo and nothing more. My PC no longer recognises the P6800 via usb or Kies - so I cannot seem to transfer anything now to or from the tab. In despair - anyone got any ideas?
Welcome to the forums jonesli, glad to have you here :)
First off here is your device forum: Samsung Galaxy Tab 7.7 - Android Forums
Secondly, have you tried performing a factory reset, this can usually solve some of these issues, like what you are having, a "bootloop".
Try doing this by booting up into recovery and into CWM and performing a Factory reset, which will delete all of your data.
Hope this helps and thanks for joining :D
Thanks so much for your quick reply. I guess I just panicked. When I calmed down I realised I could restore the original OS from ClockworkMod "restore". Once up and running again, I regained my courage and tried the upgrade once more. I re-transferred the zips from my pc and reran the whole process - and it worked this time! Now feeling my way round Jelly Bean.
