Root invalid destination address, ph # unknown
ups2525
Member
I'm on Quattrimus cm10 1.0 and can't send a multimedia text (picture text) I'm given an error message that reads invalid destination address. The only other thing I have found is under about phone my phone number reads unknown. I have tried everything to fix this and I'm outta ideas...PLEEEESE someone help...............
Probably faulty sim card, or not activated. Try to cab flash back to stock and see if it works. That sounds more like a phone issue and not a ROM issue
I thought you left the Spectrum... Sounds like a SIM/NV issue. Are you getting a correct IMEI reading?
THANKS FOR TAKING THE TIME TO RESPOND GUYS!!!!
I didn't backup the IMEI so I don't know how to confirm if its valid/correct...???
I did take a break from the Spec until I stumbled on tdm's cm10 and couldn't resist. I hated walking away from the Spec the way I did. I had such high hopes for my Spec and felt that there was some unfinished business. A few days later my mom's device took a swim in her glass of wine so I once again trusted the CyanogenMod team enough to hand it over to my very own mother. A few days later and back home in Houston she discovered that she could receive a mms but couldn't send one.
Now fast forward to today & I flashed IcyFusion v4.0 and upon setup her phone # was displayed and prompted that the SIM was already setup. I did a victory lap around the house, sat back down , reluctantly went 'old school' and setup Backup Assistant and sure enough MMS was fully functional.
NOW...on IcyFusion v4.0 I initially had a solid data connection buuuuuut (drum role please) I have lost the data connection and although I have tried everything I can think of once again our beloved Spec has stumped me :confused:. Anyone care to chime in...
Set network to SIM and not NV. Use the option with the most connections. The CDMA/Evdo/Edge/4G/WMax/GSM. Just pick the longest one. You may want to try flashing the ZV7 baseband. Sounds like an odd SIM NV issue. Also the IMEI will be in about phone and should match the serial on the back of your phone under battery. Should be fine though, as you get data and messages, would be soft bricked otherwise.
Thank you steamer86! Changes made & rebooted.
Can you post a link to the ZV7 baseband?
*EDIT* found the ZV7
