Copenhagen69
Member
Like the title says ... is there a way to clear open programs with the S3 the way apple has their iPhone setup?
hold home, go to task manager, active applications. then click on the apps and then hit end or end all.
That's all too much work for me, so I use an app called multitask manager, which lets you do the same thing by just hitting home once to bring up a list of all the apps you have running. Then you can kill them or tap them to switch back and forth between them.
I can't believe I still have to download an app to do that. It should be built in if you ask me.
yeah, I guess it does. I just wish there was an option to just show active applications on that screen.
You really don't need to do this. The Android operating system will close out extra programs automatically as it needs to.
