iphone texts
  • Start date Start date
What kind of phone do you have?
Did you previously own an iPhone here moving to your current android phone?
If that is the case you need to call your carrier and tell them your not an iphone user anymore and that should do it
Actually, if you had an iPhone, you have to turn it on and disassociate it from iMessage. As long as iMessage thinks that your phone is associated with it, the texts are going to your iPhone. (The carrier doesn't control iMessage, and trusting Apple to do it for you, even if they would, which they won't, would be ... shall we say a bit foolish?)
But if you no longer have the device then a simple call to the carrier will take care of it.
Happened to 2 friends of mine when they upgraded from a iPhone 4s to a GS4........
