iphone user needs help!
3djedi
well, I just discovered the wonderful world of launchers. I can't believe how much you can customize these android phones! I downloaded and installed the Nova launcher and it is very cool but how do you go back to the stock HTC sense launcher? Is uninstalling Nova the only way? Thanks!
I think on the AT&T handsets, there's an option in settings called App associations or something? You should be able to change your launcher there.
Alternatively head to Settings - Apps - All - Nova - Clear Defaults.
Or press the home button, that might also work.
You could try one of the launcher managers from the market. There used to be one called something like "clear default home." I'm sure there are a few. You can then use it to switch between a few different launchers and stock.
