TheDarkShadow
I figured out how you can use Peel Smart Remote in Cyanogenmod (and theoretically any custom ROM). Your device will need to be rooted first however. If you (after rooting) go to the Play Store and download (a) Peel Smart Remote and (b) Any build.prop editor. After both are installed go to the build.prop editor and find ro.cm.device (or whichever field has the device number in your rom, it will probably be p3100 for you) and change it to p3113. Restart your device and your IR Blaster should work!
If this worked for you please thank me by clicking thanks!
I tested this on my Rooted Samsung Galaxy Tab 2 7.0 running Cyanogenmod 10.2. I am not responsible for any damage you cause to your system or tablet using the build.prop editor or any other root app.
