There is no IR Blaster on the Samsung Galaxy S2. If you are an Xfinity Cable services user there is an app in the Play Store called Xfinity TV that shows you what's on and allows you to change channels on several TVs in the same house from 1 spot. I think it uses WiFi somehow but I'm really not sure. I'm sure it works though. I use it all the time.
