Is there a way to retrieve data from the G5?
Upon pressing the power on switch, it loads to the enter PIN screen. After PIN is entered, the screen cycles, then stops on the blue screen with yellow Motorola logo and white text: powered by android. After several seconds, the screen goes black very briefly then returns to the blue Motorola logo and white text.
Pressing the power & volume down buttons simultaneously caused the "APF Fastboot Flash Mode to appear on the screen.
Pressing the power button next to "RESTART BOOTLOADER" does so with "START" next to power button. Pressing the button causes the above sequence to repeat.
