Is it possible on an android tablet?
caunyd
Hi guys. I plan on replacing my car radio/head unit with a Nexus 7. Using my iPhone, I'd like to make and receive calls in my car through the Nexus 7, much like stock bluetooth phone integration in most car systems. I'd want the sound from phone calls to come from my car speakers.
I'd also like to have a small microphone installed close to the steering wheel, that runs and connects to the Nexus 7, for clarity of my voice for the caller on the other end.
Do you guys know if this is possible? Can you suggest Apps and hardware that I would need to accomplish this goal? Thanks.
basically, you're looking for a way to run/replace the cars radio electronics with the nexus device? and then attaching the phone, via bluetooth, to the nexus?
if it's possible, it will require WAY more than an app. i'd say head over to a car forum and simply ask about replacing the radio with a tablet - since i believe that's basically the crux of what you're asking here.
the phone attaching to the nexus you can probably find something on here about, and i'd be surprised if there wasn't a way to get that functioning. i don't know it offhand, but i may have to look into it now, just for my own curiosity.
either way this turns out for you, it's an interesting project and i hope it goes your way.
