Help Is it possible to boost signal strength?
chuck-sc
Does anybody know if there is a way to boost your signal strenght? In my office I barely get phone signal and one of the reasons I went to VM was to be able to surf the net without using the company's wireless net.
How about those sticker-like signal boosters, do they work?
Thanks
Id love to hear any ideas on this also. At my desk I get no signal but at the office window I get one bar...
Thanks
Depends what your goal is. If it's to waste money, they work great! If they actually worked to boost signals in phones, the phone manufacturers would likely already put them in the phones, but they don't.
If you are lucky you could try to get a Cell Ranger Stix 12V for only $14.95 at select Compusa Stores that would be a steal.
Otherwise, you would have to go to
1
ebay for the best deal.
For a USB version try Cell Ranger PORT USB-powered Cell Phone Booster
The reviews are mixed.
Otherwise you would have to get something like zboost and then the prices escalate significantly.
Regards,
