Just out of curiousity, is it possible to skip boost activation for this phone and use it primarily as a Wi-Fi device? (will activate once I get the money to pay for the plan)
Thanks
Thanks, I thought this phone would be a better option against the 16 GB Moto G. I mean, removable battery, and expandable storage, much better. (Amazon sells its for just $199.99)
Exactly why I chose it over the moto g as well. The f7 screen is better as well. Both same price but the f7 beats the moto by a little. It comes with little bloatware.
Just that you can only use it on boost
Thanks
Hello sir !
Here is to do:
- Turn on Airplane Mode
- Turn on & establish a Wifi-connection.
- Restart phone
What this does ..
- Disables activation on restart
- Saves battery since the phone is no longer pinging the cellular connection
Didn't work. It still tries to "confirm activation" every time.
Is there a way around like jumping right into the settings menu
That means it can be disabled
Which app would I need to uninstall so it wouldn't annoy me every restart?
I'm pretty sure there is a an app called Activation.apk in the system folder.
Is it really gone didn't know you has rootRemoved it with root browser and it still tries to reactivate the account every restart.
Yea didn't know you had root access can you logcat? Via adb
Do you have android SDK on your computer?
