Is it possible
New to the forum and had a little nosey around so apologies if this question has been asked a million times.
Is it possible to mass install apps on the nexus 7? I ask as our school has purchased 25 nexus' and I would like to be able to download and install on mass any thoughts or ideas?
Each phone will have a unique gmail account, but you can also add additional gmail accounts. Add a "Master" gmail account, don't sync anything except the play store stuff and then set each unit to use that gmail account for the play store. You will then be able to administer the apps on each unit form that gmail account online (from a computer.) I don't think you can "mass" install, but you can install to each device from the same session from the same computer. It will at least keep you from having to handle each phone multiple times.
BigRedGonzo
It might be possible to create backup of a phone with all the apps etc, and then restrore it to the other phones.
