bobbyelliott
I have had an HTC Desire via T-Mobile UK for a couple of months. It runs Android 2.1 with HTC's Sense interface. I have made no modifications to the phone. This evening the phone would not turn off so I removed the battery. Then it would not boot.
When I press the power button, the screen comes on, the phone vibrates (once) and I get the red ring -- and that's it. It sits with a blank screen apart from the red ring/disc.
I have tried removing the battery (that's the only way to switch it off), removing memory card and SIM. Still nothing. Then I tried a factory reset by clearing the memory, which appeared to work -- but no improvement. It remains stuck at the red disc.
Is my phone goosed? Is this a hardware fault?
The only thing I did before this problem was to try to install Swype using a APK file via my memory card and installing a third party app installer. The app installer did not find the APK file on my memory card so I couldn't install Swype - but I noticed a lot of forced closes before I tried to switch off. I presumed switching off the phone would resolve this. Then my problems began...
