I was flashing back to stock from CM9. I had already done it successfully earlier. However this time something went wrong and I don't understand what.
1. Wiped user data and dalvik cache using CWM.
2. Used the I747UCALEM stock rom. Same file I used the first time.
3. Flashed using odin. Used PDA, and only Auto Reboot was checked.
4. Tried reflashing 3 or 4 more times with the same result.
I can't get it to turn off without pulling the battery. Trying to use the power button to turn it off just causes it to restart. In the video, the phone was powered on right before the start of the video.
Any advice welcome regarding where to go from here. Is there any way out of this situation? Thanks.
No worries, lots of folks here to help.
