Help Is My SIII Screen Normal??
Hello Guys,
Is my SIII Samoled Screen Ok??
U can see in Right side 20% part is looking bluish in 0% Brightness..
In 50% its clear..
also disabled auto screen tone, screen power saver...
If its ok then i will....... :) :) :)
My friend also has SIII but not the issue like mine...
Are all Amoled screens not same??
I dont want to Give it to samsung service centre Froad peoples...
Please Check these Attachments...
Are you saying my reply is not good?
I'm Saying you its not normal. return it.
No, i m not telling you that ur reply is not good,
u are goooooood....
i contact phone dealer and he said that it cant replace...
some are saying its normal,
Actually, i m also warried about samsung customer care,
Because in india they are froad,
They can change mobo with another, also dublicate screen replacemant...
I know because i also experience this things by samsung...
check this other website thread...
http://www.expansys.com/ft.aspx?k=253822
this man has also same Problem....
I talk to Samsung service guys, they are told me "This is Normal,
It can't repiar Because the Display is very thin, and tint is only shade of colour"
Now what to do,
you are saying thats not Normal and
service guys not repiaring
Not sure what to suggest. Mine isn't like that. If they won't repair it, maybe you must keep sending them messages until they do.
