Root Is overlocking a big battery drain?
DJAlmix
Is say running the phone at full 600MZ a huge battery drain versus 320?
(Sorry for asking about i a million questions)
320 shouldn't even be able to run the android OS :/.... But running higher than 600mhz shouldn't have a big increase on battery drain because the kernel uses the same voltages so no real increase in need for power occurs
Alright thanks, yeah I feel really dumb now (as I have been ruinning my Ally at 320 this whole time) :P
Now, insted of creating more un-needed threads I have some other questions:
1. Does this forum have an app?
2. Is there an app that you can control music with + headphones? I'm wondering because I would like to ski and play music, and when I do so I can't change the song. I was thinking of an app in the realm of say some headphones with a mic adapter and saying commands like next song, play so-and-so, pause. Ect.
3. Does the lg ally support mics? (If not I know that I could sat use a blue tooth mic and say commands)
4. My device is rooted and I have been running the latest velocity for sometime now? If and how would I go about (that is if is supported) overclocking the LG Ally?
Thanks for your support :)
Sorry for double post
(Its really hard to edit posts from the phone)
I have an old version of the market place (had to unistall updates to fixe some frozen downloads) and would like to reupdate my marketplace app, so how would I do that? I know I can't just search for the marketplace, from within itself, so I'm so lost as to how do this?
