Help Is running 3 apps at the same time fine?
spman
I want to run a dash cam (running at the background), and using multi window to run GPS app (Maps) and another app.
Would running 3 apps at the same time be fine?
You can run multi applications at the same time. Settings -> Device -> Multi window.
But as Crashdamage said, it would be heavy drain on the battery. :oops:
