Is swap on RAM ???
Hi
My HTC One V has 512MB RAM but only 377.7 MB is accessible.
I noticed that the SWAP is 134.2 MB 1!!!
377.7 + 134.2 = 511.9 !!!!!!!!!
Is the SWAP the missing RAM ?
The swap is empty !!! Can I add this swap to ram ? I have low ram problem
Thanks
#!/system/bin/sh
# =========================================================================== # NexTool Swap Enble For Sense # # $LastChangedDate: 2012-10-10 20:27:06$ # ===========================================================================
LOG_FILE=/data/swap.log if [ -e $LOG_FILE ]; then rm $LOG_FILE fi
echo "Starting swap set $( date +"%m-%d-%Y %H:%M:%S" )" | tee -a $LOG_FILE
if [ ! -e /system/xbin/busybox ]; then echo "busybox not installed" | tee -a $LOG_FILE exit -1 fi
# enable swap prtition 130m /system/xbin/busybox mkswap /dev/block/mmcblk0p27 | tee -a $LOG_FILE
# enable swap file on /mnt/emmc CREATE_EMMC_SWAPFILE=1
# mount /mnt/emmc if needed if [ -e /mnt/emmc ]; then # check if already mounted cat /proc/mounts |grep mmcblk0p32 &> /dev/null
if [ $? -eq 1 ]; then # not mounted till now busybox mount -t vfat -o nosuid,nodev /dev/block/mmcblk0p32 /mnt/emmc if [ $? -eq 1 ]; then echo "failed to mount /dev/block/mmcblk0p32 to /mnt/emmc" | tee -a $LOG_FILE CREATE_EMMC_SWAPFILE=0 fi else # mounted - check if its an ext partition cat /proc/mounts |grep mmcblk0p32 | grep ext4 &> /dev/null if [ $? -eq 1 ]; then echo "/mnt/emmc is not an ext4 partition" | tee -a $LOG_FILE CREATE_EMMC_SWAPFILE=0 fi fi else echo "/mnt/emmc not found" | tee -a $LOG_FILE CREATE_EMMC_SWAPFILE=0 fi
if [ $CREATE_EMMC_SWAPFILE -eq 1 ]; then if [ -e /mnt/emmc ]; then if [ -e /mnt/emmc/swapfile ]; then rm /mnt/emmc/swapfile fi
# 60m dd if=/dev/zero of=/mnt/emmc/swapfile bs=1024 count=61440 | tee -a $LOG_FILE /system/xbin/busybox mkswap /mnt/emmc/swapfile | tee -a $LOG_FILE /system/xbin/busybox swapon /mnt/emmc/swapfile | tee -a $LOG_FILE fi fi
/system/xbin/busybox free | tee -a $LOG_FILE cat /proc/swaps | tee -a $LOG_FILE
echo "Ending swap set $( date +"%m-%d-%Y %H:%M:%S" )" | tee -a $LOG_FILE
