Is the Device Rooted
  • Start date Start date
A
Android Question
Guest
I have a Micromax canvas 2 plus-A110Q which was rooted earlier.It got stuck on a bootloop so I reflashed its Stock ROM.After Flashing It wasn't rooted so I tried again to root it again with Root with restore by Bin4ry it completes the procedure but 'Root checker Pro' says it isn't rooted:-
Root Access is not properly configured or was not granted.
Super User Applications Status:
Superuser application - is NOT installed!
SuperSU application - is NOT installed.
System File Properties for Root Access:
Alternative Location
Check Command: ls -l /system/xbin/sudo:
Result: /system/xbin/sudo: No such file or directory
Analysis: File /system/xbin/sudo does not exist.
Standard Location
Check Command: ls -l /system/bin/su:
Result: /system/bin/su: No such file or directory
Analysis: File /system/bin/su does not exist.
Check Command: ls -l /sbin/su:
Result: /sbin/su: Permission denied
Analysis: File system permissions restricted and denied access.
Standard Location
Check Command: ls -l /system/xbin/su:
Result: ---sr---wt root root 0 2013-10-05 14:33 su
Analysis: Setuid attribute present and root user ownership present. Root access is correctly configured for this file! Executing this file can grant root access!
Root User ID and Group ID Status:
SU binary not found or not operating properly
System Environment PATH: /sbin /vendor/bin /system/sbin /system/bin /system/xbin
ADB Shell Default User:
ADB shell setting for standard access, stored in default.prop, is configured as: shell (non root) user - ro.secure=1
Is this Partial Root?
how can i get back complete Root
