The guide was written quite some time ago, since then the process has become fairly easy.Does any one know of different ways of flashing from sprint to boost mobile? I have a guide but its kinda complicated. Also, about the donor phones, does it only have to be a Sanyo Incognito or the Rant?
Sanyo Incognito and Rant are both dumb phones. Using them to flash a smartphone is practically a red flag for carriers to boot you.
so what would be a good phone to use?
Say you pay 200$ for a phone and $50 for the donor. Because dumb phones handle data differently than smart phones the carrier could tell pretty easy. They could turn your device off the day you activated, many months later, or perhaps never. Can you afford the risk? So limit it the best you can by using another smartphone. Prevails should be cheap, but you'll never get 4G.
So by using any other smartphone, the steps should be about the same just different numbers?
