Is there a charging light phone?
rlugo29
Is there supposed to be a light on this phone that indicates when it's being charged or when its done?
I have an LED question you can probably answer. Is there any LED notifications on missed calls or messages? Just bought my Galaxay Light and it doesn't but want to make sure it's not a defect or just an option the phone doesnt have.
Thanks,
Steve
Thanks,
Steve
No. There are apps that can turn the camera LED into a notification light, but it's gonna be really bright and obnoxious.
Thanks for the info. Not something I really need, just wanted to make sure something wasn't working right on the phone.
Check out NoLED from the Play store. It turns on a small graphic on your screen for missed calls or text messages and can be customized for other notifications as well. Been using this for a while now and it works great.
