E ericsloan Newbie Oct 20, 2011 #1 i have mikg ron on but i try to put any theme on it loops is there any order to load?
Rxpert83 Dr. Feelgood Oct 20, 2011 #2 For themes you are going to want to wipe dalvik cache & Cache and then flash the theme. Make a nandroid in case it doesnt work Also make sure it is compatible with your version of mikG
NaterTots Android Enthusiast Oct 20, 2011 #3 Also make sure that the theme you want to apply was set up for that Rom. I do it as Rxpert says, load SD card, Nand, wipe dalvik cache, cache, flash theme, reboot. That should do it.
Rxpert83 Dr. Feelgood Oct 20, 2011 #4 Check MikG v2.xx Themes for available themes. It looks like the Blue Glass theme was updated for 2.58
Granite1 Zercron Encrusted Tweezer Oct 20, 2011 #5 NaterTots said: Also make sure that the theme you want to apply was set up for that Rom. I do it as Rxpert says, load SD card, Nand, wipe dalvik cache, cache, unzip theme, reboot. That should do it. Click to expand... Don't unzip the file, just flash it.
