I have a Samsung Galaxy Apollo, which currently runs Android 2.1
I am aware that you cannot install apps onto your memory card on 2.1 and the 2.2 update is in April
Is there some sort of App or Computer Trickery that will let me do this?
Please Respond,
Spoggy
With Android 2.1 you can take backup on SD card, so that you can uninstall/reinstall if space is the issue. there are good applications in market. e.g. App Installer
Sandeep, I think what OP wanted to know will app2sd work on Android 2.1
Answer is you cannot install applications on memory card on a Android 2.1 device
this feature is not supported by 2.1
however there are application which can let you backup your installed application from phone memory to sd card, however this doesn't solves the purpose for most users are there are loads of applications which most users are very keen to try.
Thanks for clarification, That is what i meant in my message, I do the same think install app, try it take a backup on SD card. We need to live with it till we get 2.2.
Interestingly symbian has this features for years!
