Help Is there a way to control how often the Motorola widgets sync like there is for the Android widgets?
jshoe22
Is there a way to control how often the Motorola widgets sync like there is for the Android widgets? For example, on my Atrix the weather widget came pre loaded on the home screen. I do not see a setting in the settings menu for that item that controls how often it can sync. I saw the weather updated very frequently. The same is with the Motorola News widget. I went into settings and see no setting for the sync time. It allows me to select which news to sync but not an interval. Is there anyway way to change these intervals for the Motorola widgets? I see it can be done with others, just not Motorola's built in ones (from what I see).
Thanks
So there is no way for the Motorola Widgets individually? I know other widgets you can specify how often the update for each widget. Please let me know. Thanks
I dont believe so, I got rid of all those widgets and installed LauncherPro the second I got the phone
I like the setup. I dont't want Launcher Pro. I just want to know if the Moto widgets have that customization or if I'm going to have to just download a different weather and news apps that allows me to seup sync times.
