Root Is there a way to downgrade from 2.2.1 > 2.1
ChryzaorFlux
Hey guys
1) First i tried to root my phone via unrEVOked 3.32, it said "Firmware too recent", then i tried to downgrade my Wildfire
2) Then it said "ERROR[131] Customer ID Error", i googled it and i read up about people turning their SD card into a "Gold card" through some long process.
3) Now im here, i just want to know:
CAN I EITHER ROOT OR DOWNGRADE MY HTC WILDFIRE 2.2.1??????
Does anyone know the answer to this simple question
Can i either root or downgrade my HTC Wildfire 2.2.1
*After 6 hours*
Ok guys, I have googled soo many ways, tried soo many procedures, nearly had a heart attack because i thought i bricked my phone (reboot took way to long)
Ive decided, if you have Android 2.2.1 on Wildfire, dont try to root your phone your only wasting your time, HTC have managed to create an unbeatable patch (atm)
Hopefully in a few months or so, we will be finally able to root, but for now, im sticking with my non-rooted phone.
Peace out
hi there
been trying to get my lads wildfire downgraded to 0001 but struggling. ive followed the instructions but a bit unsure about this goldcard thing.
i downloaded the buzzdowngrade and did step 1. and i used the goldcard creator to get a goldcard image which i saved to pc. i then went to step 2 but it doesnt seem to have changed anything, im still 0002.
so.......do i need to put the goldcard image on the sd card or will it already be there? thats the only thing that seems to have stopped it working. can anyone advise how to finish the job?
thanks a lot
hi there
thanks a lot
Use the link in my signature for rooting
I suggest using the link if what i wrote wasnt clear
Erm when you download the goldcard after registering, refresh the window by exiting it and opening it again, you should see your device
click load goldcard, find where you downloaded it.
Then click Patch MMC
Done
Here is a check list of towards rooting
Gold carded SD card
Downgrade HBOOT to 1.01.0001
Obtain S-OFF from S-ON
Downgrade your Wildfire to 2.1
Root using unrEVOked
Done
Gold carded SD card
thanks :-) bit of a newbie but i dont see a link in your signature, not really sure where im sposed to be looking. ive now got the goldcard sorted ta and so im at step 2 now with no luck. i run revolution which starts up but just hangs on finding my device. looking at the advice on there it implies its a pc/driver issue.
but i did as shown in the vid except my phone was shown in device manager at the top. whern i browsed to my 'android usb drivers' folder it stated i already had the best ones, so it didnt do anything else. so as far as i know i got the best drivers.
any further advice much appreciated :-/
Sorry bout that here it is LINK
Maybe your Wildfire is connected as an external hard drive instead of an Android device
i have tried this and succesfully completed this process but m still on .0002
Completed the process as in achieved root on your Wildfire????
If that is the case then you should just use the buzzdowngrade tool to downgrade your hboot.
Wait do you have S-OFF?????
i have unlocked my wildfire . my HBOOT is 6...0002 , S-OFF and i tried to root with unrevoked but it saying 'Firmware too new.......' I must downgrade it and install another ROM to root..with unrevoked ... but want to know if i install another Rom will be locked again
All you have to do is, run an RUU that is Eclair (Android 2.1)
Then use unrEVOked, you've probably still got a Froyo ROM
