Help Is there a way to keep speaker phone as a default setting?
starfruit
I'm new to android phone so please forgive me if I'm asking a stupid question.
I read that this phone has a high radiation and I would like to use this phone primarily on a speaker. Right now I use it by tapping a button after a call is made, but is there a way to make it a usual default? Like, to make it always on speaker? as when playing music?
Thank you,
starfruit
PS: I'm also looking for a good speaker dock -- do you think you don't need a speaker (in this case like a sound stereo system) and that docking system itself is enough? My primary use will be to play music through pandra in a 2 bedroom apartment.
I've never see a dock for cellphones other than the iPhone. Why not just get a pair of amplified PC speakers? They are much cheaper than docks.
As for defaulting to the speakerphone, I would like to do that also, but there is no menu option.
There was a thread here a while back about a cellphone dock that worked with the Optimus V. Some slight modifications were needed, but in the end it worked.
You could use an app called Tasker to always default to speakerphone. It costs a few dollars but it can do a lot of things for you and your phone.
I use an app "Car Mode" that I use in the car, I suppose you could leave it enabled full time. All it does is turn on the speakerphone.
