Root is there a way to restore a saved scene?
jgalvar
I've been jumping around between roms and am currently running frankenrom b5. Every time I do a titanium restore it never restores my scene. Then I have to go back in and edit everything to get the scene back how it was before i changed roms. Any help would be great thanks!
no...say I have 7 slides (a Sense scene) with particular widgets and apps on each slide...how can I restore the scene with all slides like they were before rom change
Should running the batch file "restore all apps with data" restore the scenes? It didn't work for me when I upgraded to Franken-B5 but I think it may have been that I didn't have a custom scene saved.
desktop htc sense is the right one... but some widgets maybe broken ... but it gives you a rough idea of how it was
