robot phone
I don't know enough about how all this works to want to try rooting, but some of these stock aps are doing nothing but suck the life out of my battery. Can I do something to delete them without having to root? Thanks.
This is how I got rid of Motonav. Had to root, but it was simple when I followed these instructions.
Interesting sidenote; Motonav was in my user memory (not system) for some reason.
Yet another interesting sidenote;
Following those instructions (it's not hard to find Samsung Moment root instructions, and I didn't post root instructions) gives you access to ANY of the /system apps , not just MotoNav. Meaning the OP could erase the other applications without running terminals to do so. Just another option, sorry for posting something other then "durrr, do this!" without any real instruction.
I'll make sure not to make the same mistake twice.![]()
if u do decide to root i suggest u use this app---->Stock App Removal app v1.5
safe apps to remove--->Safe Apps to Remove - Samsung Moment Wiki
. The easiest way i found to backup is using the backup function in the reocvery. More specifically in this case the /system backup as the files in question in the OP are system apps which are stored in /system/app/, go figure
